Novaturn NS
I bought a Novaturn NS recently and have so far not been able to get it running.
I tagged onto another thread about a similar issue, so in a last ditch effort to find some answers I thought it worth starting a new thread about it, in the hope it catches someone’s eye.
These are the things I have done and the results, thanks to help from CNC Guru Martin.
I have the original PC and software with license.
Don't have the upgrade software on the PC nor do I have the original discs.
VR Turn is Version 1.39.0.0.
Made a new 9 pin- 9 pin cable from PC to control card directly from this link
https://www.denfordata.com/bb/viewtopic.php?t=231
3 fuses were removed and checked as good.
When I start the machine and software I get this:
Control board 7 segment green display shows an “E” flashing
Hit the Machine Control button and a dialogue pops up, followed by a "Downloading Program" box with "Erasing Flash" progress bar.
This produces an "8" on the display
Hit the "Home" button on the machine control dialogue and get a solid "h"
The x/z DRO's then start to climb to ridiculous figures (3500mm)
And that's about it. Software locks up.
Freezes after that.
If anyone can shed any light on either what the problem might be, or a way to diagnose it I would be very grateful indeed.
Re: Novaturn NS
It sounds like you have an issue homing which may be as simple as a axis drive fuse.
Can you post a picture of serial plate & the electrical cabinet.
Re: Novaturn NS
Hi Martin
You suggested I check the fuses in our last communication, which I did, found 3 and all were good.
Re: Novaturn NS
Can you post a picture of the electrical panel. There should be more than 3 fuses.
Re: Novaturn NS
More than 3 fuses iis great news. Hopefully the ones I didn't find are blown.
WhatsApp Image 2025-04-28 at 15.35.02.jpeg (207.67 KiB) Viewed 17408 times
WhatsApp Image 2025-04-28 at 15.35.01 (6).jpeg (211.06 KiB) Viewed 17408 times
WhatsApp Image 2025-04-28 at 15.35.01 (5).jpeg (274.73 KiB) Viewed 17408 times
WhatsApp Image 2025-04-28 at 15.35.01 (3).jpeg (259.08 KiB) Viewed 17408 times
WhatsApp Image 2025-04-28 at 15.35.01.jpeg (240.36 KiB) Viewed 17408 times
WhatsApp Image 2025-04-28 at 15.35.01 (1).jpeg (180.12 KiB) Viewed 17408 times
Re: Novaturn NS
Is there a Novaturn NS electronics circuit drawing or schematic with fuse locations on it?
Re: Novaturn NS
Hope these help
NVT-D2E.pdf
(29.57 KiB) Downloaded 356 times
Re: Novaturn NS
Many thanks Martin. I'll investigate and let you know how I get on.
Re: Novaturn NS
All fuses found and checked. All still good though, so not the problem. :(
Re: Novaturn NS
Just had a look back.
It looks like the Motor connections are loose. Can you check.
Motor Connections.JPG (17.24 KiB) Viewed 11887 times
Re: Novaturn NS
Still no joy. All fuses checked as good and all connectors reseated.
Re: Novaturn NS
I am not sure where to look now.
Where abouts are you located??
Re: Novaturn NS
I'm in the Midlands, Close to Coventry.
Re: Novaturn NS
We could arrange a service visit or you could bring the machine up to us.
We are in brighouse HD6 1QF.
Let me know if you need a quote.
Re: Novaturn NS
Please do quote for me Martin.
Re: Novaturn NS
I'll DM my contact details
Re: Novaturn NS
An update on the Novaturn:
After going through all the steps advised by Martin earlier in this thread, the only logical option for me was to arrange a service call from Denford.
As this machine is being used for my work I had justification for the expence so went ahead and booked the visit.
Service engineer Nick arrived and with Martin (via video call) spend a couple hours faultfinding, swapping boards and checking the system.
Of all the things that could have been the problem, it was finally traced to a broken emergency stop button!
That was a hell of an expensive button, but there was no way I would ever have been able to track it down, so the service call was worth the money.
This forum, it's moderators and members have been an absolute lifeline with this machine (and my Novamill come to think of it) so I have to thank Denford, Martin, Nick and all the members for their invaluable help in getting my machine running.
Can't find anything other than gratitude for a great British company.
Every project I work on will now be round :lol:
