Help not displayed on windows7
Cannot seem to get to the machine help to display. The help tries to connect to the internet?????
Re: VR Turning v1.28 released 30th Nov 2011
Works OK here.
Is it win 7 or vista ?
Are you trying from the menu or F1 key ? or are both not working ?
This is from the ff1 or the help menu on Win 7 and on 2 new XP installs
See screen shot.
Help window.jpg (70.97 KiB) Viewed 28775 times
What format is the help file stored as and where should it be located on the install?
I cannaot find a help directory
in C:\Program Files\Denford\VRTurning
or C:\Program Files (x86)\Denford\VRTurning
there is Turn.hlp and Vrturn.hlp
both files exist but open microsoft help.
Is this file accociation?
help file location.jpg (146.21 KiB) Viewed 28773 times
I think I have the answer.
The machines with the problem are all windows 7.
It seems this version does not have the software installed to view older help files.
The following link should resolve this.
https://support.microsoft.com/kb/917607
Will confirm when tested.
Downloading and running this exe has resolved the problem.
https://www.microsoft.com/downloads/deta ... 8e02b32a2c
Those files will be on the next VR Turning CD... under \Utility\WinHelp4Win7
