Novaturn NS
Deck36
Novaturn NS
Post by Deck36 » Wed 23 Apr , 2025 11:03 am
I bought a Novaturn NS recently and have so far not been able to get it running.
I tagged onto another thread about a similar issue, so in a last ditch effort to find some answers I thought it worth starting a new thread about it, in the hope it catches someone’s eye.
These are the things I have done and the results, thanks to help from CNC Guru Martin.
I have the original PC and software with license.
Don't have the upgrade software on the PC nor do I have the original discs.
VR Turn is Version 1.39.0.0.
Made a new 9 pin- 9 pin cable from PC to control card directly from this link
https://www.denfordata.com/bb/viewtopic.php?t=231
3 fuses were removed and checked as good.
When I start the machine and software I get this:
Control board 7 segment green display shows an “E” flashing
Hit the Machine Control button and a dialogue pops up, followed by a "Downloading Program" box with "Erasing Flash" progress bar.
This produces an "8" on the display
Hit the "Home" button on the machine control dialogue and get a solid "h"
The x/z DRO's then start to climb to ridiculous figures (3500mm)
And that's about it. Software locks up.
Freezes after that.
If anyone can shed any light on either what the problem might be, or a way to diagnose it I would be very grateful indeed.
Re: Novaturn NS
Post by Martin » Thu 24 Apr , 2025 14:46 pm
It sounds like you have an issue homing which may be as simple as a axis drive fuse.
Can you post a picture of serial plate & the electrical cabinet.
Deck36
Re: Novaturn NS
Post by Deck36 » Fri 25 Apr , 2025 17:49 pm
Hi Martin
You suggested I check the fuses in our last communication, which I did, found 3 and all were good.
Re: Novaturn NS
Post by Martin » Mon 28 Apr , 2025 11:39 am
Can you post a picture of the electrical panel. There should be more than 3 fuses.
Deck36
Re: Novaturn NS
Post by Deck36 » Mon 28 Apr , 2025 15:43 pm
More than 3 fuses iis great news. Hopefully the ones I didn't find are blown.
WhatsApp Image 2025-04-28 at 15.35.02.jpeg (207.67 KiB) Viewed 9409 times
WhatsApp Image 2025-04-28 at 15.35.01 (6).jpeg (211.06 KiB) Viewed 9409 times
WhatsApp Image 2025-04-28 at 15.35.01 (5).jpeg (274.73 KiB) Viewed 9409 times
WhatsApp Image 2025-04-28 at 15.35.01 (3).jpeg (259.08 KiB) Viewed 9409 times
WhatsApp Image 2025-04-28 at 15.35.01.jpeg (240.36 KiB) Viewed 9409 times
WhatsApp Image 2025-04-28 at 15.35.01 (1).jpeg (180.12 KiB) Viewed 9409 times
Deck36
Re: Novaturn NS
Post by Deck36 » Fri 23 May , 2025 8:57 am
Is there a Novaturn NS electronics circuit drawing or schematic with fuse locations on it?
Re: Novaturn NS
Post by Martin » Fri 30 May , 2025 8:20 am
Hope these help
NVT-D2E.pdf
(29.57 KiB) Downloaded 159 times
Deck36
Re: Novaturn NS
Post by Deck36 » Fri 30 May , 2025 9:15 am
Many thanks Martin. I'll investigate and let you know how I get on.
Deck36
Re: Novaturn NS
Post by Deck36 » Thu 12 Jun , 2025 11:05 am
All fuses found and checked. All still good though, so not the problem. :(
Re: Novaturn NS
Post by Martin » Fri 13 Jun , 2025 8:13 am
Just had a look back.
It looks like the Motor connections are loose. Can you check.
Motor Connections.JPG (17.24 KiB) Viewed 3888 times
Deck36
Re: Novaturn NS
Post by Deck36 » Mon 23 Jun , 2025 19:47 pm
Still no joy. All fuses checked as good and all connectors reseated.
Re: Novaturn NS
Post by Martin » Tue 24 Jun , 2025 13:22 pm
I am not sure where to look now.
Where abouts are you located??
Deck36
Re: Novaturn NS
Post by Deck36 » Wed 25 Jun , 2025 21:47 pm
I'm in the Midlands, Close to Coventry.
Re: Novaturn NS
Post by Martin » Thu 26 Jun , 2025 11:27 am
We could arrange a service visit or you could bring the machine up to us.
We are in brighouse HD6 1QF.
Let me know if you need a quote.
Deck36
Re: Novaturn NS
Post by Deck36 » Fri 27 Jun , 2025 0:54 am
Please do quote for me Martin.
Deck36
Re: Novaturn NS
Post by Deck36 » Tue 01 Jul , 2025 6:39 am
I'll DM my contact details
