One of my spoke schools have a Trend vacuum table which they are using with the Wood Vac vacuum cleaner and are experiencing the usual noise and overheating problems.
I am looking to purchase a suitable pump to replace the Wood Vac. Has anyone got a new or used pump? OR Can anyone tell me the spec. of a suitable pump so that I can source one?
Bob,
We offer a stand alone pump at a cost of £450 part no BI00843N
We supply this in a kit with Vac pots.
KIT TO0 INCLUDE:
STANDARD ROTARY VANE VACUUM PUMP
SINGLE PHASE 240V 0.1KW 50HZ
MOTOR.
1/8" - 6MM TUBE CONNECTOR
MOUNTING FRAME AND GAUGE
This runs with very little noise
The other Pump we use generally is mounted inside the machine but the cabinet has been redesigned to take it.
KIT TO0 INCLUDE:
MOTOR.
