Vacuum pump for a MicroRouter
One of my spoke schools have a Trend vacuum table which they are using with the Wood Vac vacuum cleaner and are experiencing the usual noise and overheating problems.
I am looking to purchase a suitable pump to replace the Wood Vac. Has anyone got a new or used pump? OR Can anyone tell me the spec. of a suitable pump so that I can source one?
Bob,
We offer a stand alone pump at a cost of £450 part no BI00843N
We supply this in a kit with Vac pots.
KIT TO0 INCLUDE:
STANDARD ROTARY VANE VACUUM PUMP
SINGLE PHASE 240V 0.1KW 50HZ
MOTOR.
1/8" - 6MM TUBE CONNECTOR
MOUNTING FRAME AND GAUGE
This runs with very little noise :D
The other Pump we use generally is mounted inside the machine but the cabinet has been redesigned to take it.
