CYCLONE POWER SUPPLY AGAIN.
Does anyone have a manual and wiring diagram for a Denford cyclone with a seperate power supply (see earlier question) and fanuc control.
Please can you supply the serial number of the machine and the date supplied?
serial number CY02020E Year of manufacture 1990
Have a look at these..... :lol:
(If you don't have anything that opens DWG, then try QuickCAM 2D - the Demo version will import DWG and DXF, but not let you print)
I presume being 1990, that its an OTA control ? These dwgs are a bit later than that, but should be quite close.
cyclone-fanuc-ota-denford-circa-1993.zip
Cyclone Fanuc OTA drawings from around 1993
(717 KiB) Downloaded 1203 times
The machine is fitted with fanuc 21i-TA control
If its a 21i, then it can't be a 1990 machine :?
Here are the drawings anyway..
cyclone-fanuc-21i-electrical-drawings.zip
(1.24 MiB) Downloaded 1218 times
Had another look at machine. On the id plate for the lathe it has a serial number for the the electrical system. This being 9023675.
