Hi, I am having issues connecting pc to machine (microrouter pro), I get the following error messages.
Drive reports incorrect toggle bit.????
And
Must use a setxxxlink function.????
Can anyone help and advise what to do??
Thankyou
What is the colour of the 7 segment LED in the electrical panel?
If it is not red then try to connect using EasyUgrader.
Hi it was green.
I have just tried the easy up grader, but still get error message
Drive reports incorrect toggle bit.....
Have I got baud rate, bit rate etc setup wrong,??
Do you know what these should be set at?
After much investigation it would appear to be an issue with the pc, I was originally running mach3 on the system with my other router, but now I was planning to run a pro router on the same system using vr milling, a windows optimization check list I had done recommended by mach clearly has issues with other programmes.
