Can I cut Brass Sheet ?
mickb
Hardware/Software: VLS 4.60
XP
CorelDraw
Post by mickb » Mon 25 Nov , 2013 11:45 am
Hi there - Can I safely cut brass sheet say 0.2mm thickness with my 50W VLS 4.60 ?
If so what settings would you suggest ?
Re: Can I cut Brass Sheet ?
Post by Martin » Mon 25 Nov , 2013 13:36 pm
No!
It will not cut any metals. You can etch some metals but the surface would need to be coated. Metal marking compound, anodised, etc.
mickb
XP
CorelDraw
Post by mickb » Tue 26 Nov , 2013 15:22 pm
OK :cry:
