Can I cut Brass Sheet ?
Hi there - Can I safely cut brass sheet say 0.2mm thickness with my 50W VLS 4.60 ?
If so what settings would you suggest ?
Re: Can I cut Brass Sheet ?
No!
It will not cut any metals. You can etch some metals but the surface would need to be coated. Metal marking compound, anodised, etc.
OK :cry:
