triac spindle motor (servo)
comet
Post by comet » Wed 07 Nov , 2012 22:40 pm
Hi I have updated my triac with later steppers/drivers also mach 3.
The machine has the servo type spindle motor,
I would like to control it passively with just a switch and a pot for now,how do I do that?
is there any electronics schematics available?
cheers
tony
Re: triac spindle motor (servo)
Post by Martin » Thu 08 Nov , 2012 1:44 am
What drive does the Triac have?
comet
Post by comet » Thu 08 Nov , 2012 9:13 am
not sure havnt pulled the tray out yet only got the machine yesterday ill post back later with the details.
for now serial number tr14039f built may 89
Tony
Post by Denford Admin » Thu 08 Nov , 2012 10:59 am
Will it be this ?
viewtopic.php?f=15&t=2275
comet
Post by comet » Thu 08 Nov , 2012 19:02 pm
No its a linx 80, is that good or bad?
Tony
comet
Post by comet » Thu 08 Nov , 2012 20:39 pm
Ok found the manual it all looks straight forward,hope it works,as i havnt put power to it yet.
if not Ive got a eurotherm 508 that should do the job.
is there any market for all the original triac electronics? as im mach3ing this with new steppers and drivers?
Tony
angel-tech
Hardware/Software: .....
4 Quatros
3 Oracs
2 Easiturn atc
12 station lathe atc
Mach 3
Post by angel-tech » Thu 08 Nov , 2012 23:33 pm
i may be interested in the drivers and psu, and the steppers.
comet
Post by comet » Fri 09 Nov , 2012 9:37 am
Angel,
Im in worcester,whereabouts are you?
angel-tech
4 Quatros
3 Oracs
2 Easiturn atc
Mach 3
Post by angel-tech » Fri 09 Nov , 2012 10:14 am
sunny Cardiff
comet
Post by comet » Fri 09 Nov , 2012 10:39 am
Ok what bits exactly do you want?
angel-tech
4 Quatros
3 Oracs
2 Easiturn atc
Mach 3
Post by angel-tech » Fri 09 Nov , 2012 10:44 am
stepper drivers, steppers, stepper power supply. Which stepper drivers are they, sd2/3 i expect.
comet
Post by comet » Fri 09 Nov , 2012 10:56 am
ive got 3 drives and the xand y steppers no z stepper
steppers are mae? I assume it all works when you power up the base the screen comes on with no error messages?
Tony
angel-tech
4 Quatros
3 Oracs
2 Easiturn atc
Mach 3
Post by angel-tech » Fri 09 Nov , 2012 11:04 am
i'm off to manchester sunday, would it be possible to pop in on the way home.
comet
Post by comet » Fri 09 Nov , 2012 23:06 pm
sure,but to be honest id rather you take the lot with you,ie the tray with everything minus the motor controller,which works!!
make me an offer i cant refuse! as it will save me ebaying it all can you pm me?
tony
angel-tech
4 Quatros
3 Oracs
2 Easiturn atc
Mach 3
Post by angel-tech » Fri 09 Nov , 2012 23:22 pm
i'm happy to take the whole lot minus the inverter..
I'll pm you my number so we can have a chat.
