Any ever put a servo motor in a Triac VMC?
anyone ever replaced with spindle motor on a triac vmc with a servo motor?
Re: Any ever put a servo motor in a Triac VMC?
Yes, our later machine the VMC 1300 Pro uses a Baldor 6000RPM servo motor.
Be aware that the spindle head bearings are upgraded on the PRO machine, they are better quality and a matched, preloaded pair.
...the standard VMC 1300 machine uses the same bearings and a similar spindle to the Triac machine you will have.
is replacing the bearings a difficult job?
Some info here:
viewtopic.php?t=1953
viewtopic.php?f=45&t=3632
And probably more...
thanks for the links, looks like a big faff :-(
You could still fit a servo without changing the bearings if you keep the speed to 4000RPM max.
ah right im with you.
many thanks
ill keep an eye on ebay see what comes up. any recommendations for a drive board?
ive only owned the triac for a month so am very new to all this.
i probably know the anwser to this but ill ask anyway, has anyone tried / is it possible to tap threads using the stock motor on this machine without a tapping head. so tap straight in chuck?
Mr Magoo, Martin, Steve
