Easiturn 3 display/monitor -adjust brightness
Anyone out there know how to adjust ( increase ) the brightness of the display
Thanks in anticipation
Re: Easiturn 3 display/monitor
If it is the internal monitor in the control panel remove the cover & adjust the Brightness pot on the card directly below the tube. If I remember correctly if you power up & press X then it shoiuld display a full screnn of X's which should make it easier.
Thanks Martin for the quick response, will try next week when the m/c is not being used
All the Best
techy
Tried it today and it worked fine, you were right about the screen full of 'Xs'
Thanks again
