Anyone out there know how to adjust ( increase ) the brightness of the display
Thanks in anticipation
If it is the internal monitor in the control panel remove the cover & adjust the Brightness pot on the card directly below the tube. If I remember correctly if you power up & press X then it shoiuld display a full screnn of X's which should make it easier.
Thanks Martin for the quick response, will try next week when the m/c is not being used
All the Best
techy
All the Best
techy
Tried it today and it worked fine, you were right about the screen full of 'Xs'
Thanks again
Thanks again
