Easy Change tool holders
Does anyone have dimensioned drawings for the spindle fitting end of Easy Change toolholders please?
John.
Re: Easy Change tool holders
Try Coventry Toolholders site for the info.
https://www.coventrytoolholders.co.uk/pr ... change.htm
Thanks - as they don't give dimensions they are obviously potentially easy to make!
the critical dimensions are going to be the taper diameter and the rear face of the groove.
I think this holder is the same
not sure...
https://www.homemetalshopclub.org/news/1 ... &view=fitH
newsletter1107.pdf
(1.09 MiB) Downloaded 3560 times
That looks like the one! Well spotted, and thanks. John.
really usefull, thanks
You can buy these from J&L if you get stuck and if you look out for the discounts you can save a few bob. I think the easy change system is great but takes up a lot of room on an already limited head height machine. hence why I raised the column. There are some nice ISO30 collet holders about though.
