Triac Fanuc OMC Electrical Drawings
Post by Martin » Mon 08 Mar , 2010 11:20 am
Triac Fanuc OMC electrcail drawings
Triac Fanuc OMC.pdf
(758.2 KiB) Downloaded 1989 times
jaycnc
Re: Triac Fanuc OMC Electrical Drawings
Post by jaycnc » Mon 08 Mar , 2010 11:55 am
Thanks for the atatchments guys its much appreciated.
After doing some searching last night it would appear that the control boards are still made for these and i also found a place that repairs them for £168 so alls not lost if it turns out to be the drive card.
Some how i feel a lot better now :lolol:
Post by Denford Admin » Mon 08 Mar , 2010 12:11 pm
We should be able to supply a new sprint drive which is still used, from what I can see, (but don't quote me on this) they are just under £200
It's worth emailing sales :bert: denford :ernie: co :ernie: uk
jaycnc
Post by jaycnc » Mon 08 Mar , 2010 21:45 pm
Denford Admin wrote:We should be able to supply a new sprint drive which is still used, from what I can see, (but don't quote me on this) they are just under £200
Will these work as a direct replacment to what i already have and is there much setting up to be done at all??
Post by Martin » Mon 08 Mar , 2010 23:49 pm
You would need a tacho to read the spindle speed when setting it up but the rest is straightforward.
If you have the current drive repaired check that the pots are set to the same position as they were when you fitt it back in.
Post by Steve » Tue 09 Mar , 2010 10:08 am
BI00307H Sprint 1200 sells for £198 and we have 4 in stock.
Post by Martin » Tue 09 Mar , 2010 17:37 pm
Does it not need to be a Sprint 1200i with it being on a Fanuc
Post by Denford Admin » Wed 10 Mar , 2010 10:41 am
Don't our suppliers still do the Lynx by the way ?
