Triac inverter manual
Desperately need a datasheet or manual for the Brown Pestell inverter!
Control voltage not changing rpm!
any help appreciated!
Early Denford metric manual Mill
Retrofitted Triac
Easiturn-3
I'm sure there's one on the forum - use the search facility
but you'd probably be better buying a new one
www.la-coterie.com
I did before I posted, the only one I could find was the IMO Jaguar
viewtopic.php?t=864
Which bears certain likeness to the Brown one, however setting up is very likely to be different.
Retrofitted Triac
Easiturn-3
There is also a parajust manual -
viewtopic.php?t=462&highlight=parajust
Thanks David,
Also found an earlier diagram of the Brown Pestell inverter here!
viewtopic.php?t=1243&highlight=pestell
There are Terminal-use-variations in these depending on year built so need care with connections!
Yes I tend to agree, these inverters are quite primitive by todays standards!
Retrofitted Triac
Easiturn-3
