Desperately need a datasheet or manual for the Brown Pestell inverter!
Control voltage not changing rpm!
any help appreciated!
    				    					I'm sure there's one on the forum - use the search facility
but you'd probably be better buying a new one
www.la-coterie.com
    				    			www.la-coterie.com
I did before I posted, the only one I could find was the IMO Jaguar
viewtopic.php?t=864
Which bears certain likeness to the Brown one, however setting up is very likely to be different.
    				    					viewtopic.php?t=864
Early Denford metric manual Mill
Retrofitted Triac
Easiturn-3
    				    			Retrofitted Triac
Easiturn-3
Thanks David,
Also found an earlier diagram of the Brown Pestell inverter here!
viewtopic.php?t=1243&highlight=pestell
There are Terminal-use-variations in these depending on year built so need care with connections!
Triac whizz said:
Yes I tend to agree, these inverters are quite primitive by todays standards!but you'd probably be better buying a new one
Retrofitted Triac
Easiturn-3
    				    			Retrofitted Triac
Easiturn-3
