Denford Triac Miller - Keyboard gives wrong values
wlphorseman
Post by wlphorseman » Wed 27 Jan , 2010 16:28 pm
Hi, I have a Denford Triac Miller and the key board has gone wrong when i press x i get y and when i press 9 i get 6 can any one help
Re: Denford Triac Miller - Keyboard gives wrong values
Post by Martin » Thu 28 Jan , 2010 9:26 am
Can you supply more information please.
Control type?
Software version?
Keypad?
wlphorseman
Post by wlphorseman » Thu 28 Jan , 2010 22:40 pm
sorry dont know whot the software is can send you some photos if that helps the mother board is made by north east eletronics but dont seem to be able to get in touch with them i only imput the program though the key pad can this machine be convertd to run from a laptop and any though to the cost
Post by Martin » Fri 29 Jan , 2010 7:57 am
Triac PNC3 then.
Have you tried running the keyboard test? -
Hold a button in & power up the control. You can then
press any button to display it's relevant number. I am
not sure what order the buttons go in but it should help to check & work out where
the fault is.
wlphorseman
Post by wlphorseman » Fri 29 Jan , 2010 11:38 am
thanks but whitch button do i hold in ? to test key pad and after do i press all the key pad numbers
Post by Steve » Fri 29 Jan , 2010 12:12 pm
wlphorseman
Post by wlphorseman » Sat 30 Jan , 2010 14:05 pm
have tryed the key board test and it seems ok tried the miller today and it did its job fine so dont know whot is wrong till next time it plays up
