Mirac Tool changer
Can anybody please help my micac lathe toolchanger will not index.
Am using software version 2.25
Serial no of machine 30129
It changes tools in software _ screen changes tool number and offset number
Have a flashing red led 5 flaches then repeats this happens as soon as spindle contact pulls
in. If push reset button on card flahing stops but still no joy.
All fuses seem ok
Thank you
Re: Mirac Tool changer
Apparently that is not proper serial no. This is a Mirac GSM type. We need the correct number to identify the toolchanger. Could be a Baruffaldi ?
It sounds as though the jumper on the GSM control card is missing.
Has the toolpost worked before?
There is a bank of about 7 sets of pins running vertically just below the centre of the main LCB3 card.
I can`t remember exactly but it rings a bell that it is jumper 5 ( may be jumper 2) that is required to select a automatic tool changer.
Yes the toolchanger was working before
However I have had to make a new floppy disk for the machine as it has
no hard drive in it and the floppy disk drive stopped working
Have attached photo of board as not sure where jumbers are.
This board to my knowledge not been touched
denford board.JPG (67.9 KiB) Viewed 17458 times
The record sheet for the Mirac serial number 30129D shows that it is fitted with a LCB3 control card & a Baruffaldi TOE80 6 station toolpost.
It states that the software version sent out was TOE80 V2.11. which seems strange. I am unable to locate the option file for this machine.
Is it possible to coppy the mirac.opt from one of the earlier discs?
I have attached a photo of where the links are on the LCB3 board but it does sound more like a software issue.
I have managed to locate an option file for a Mirac with the same TOE80 6station toolpost fitted.
I presume it will be the following lines that will be missing from you’re opt file.
mintool 1
maxtool 6
TCTYPE 2
MiracOption.pdf
(57.52 KiB) Downloaded 1129 times
Thank you
On friday a put jumper on the board and it pulled contactor in
Think problem is break related
Will not be able to try software fix till this evening
Thanks again
This is the opt file machine using now
MIRAC_opt file.txt
(370 Bytes) Downloaded 1204 times
Here is the final .opt file with machine working
Please note this machine does not need jumper on LCB3 to work toolchanger
Thank you to everybody who has helped
MIRAC_opt file.txt
(370 Bytes) Downloaded 1245 times
Thanks for posting the working Opt file.
Hi tractorman, just compared the two .txt files you posted and they are both identical.
In case anyone else has this issue, can you clarify what you changed - did you have to remove the Open bracket in front of TCTYPE 2 ?
Yes removed bracket and removed jumber of lcb3
Ok thanks, so this is the working .opt file:
Code: Select all
AUTOERROR 0
DRAGMARKING 0
DISPLAYSIZE 3
NARROWSIMBOX 0
utils_menu_1 Dos Access
utils_go_1 dos
utils_menu_2 Turning Designer
utils_go_2 ldesign
HIGHFEED 1200
SLAVE_XDATUMFEED 1200
SLAVE_ZDATUMFEED 1200
mirac_sdevice machine
{SLAVE_SPINDLEFACTOR 1.2
mintool 1
maxtool 8
dc_brake 0
TCTYPE 2
MACHINEEXTENTZ 220
MOVERANGEZ 220
SLAVE_BANK 1
CHUCKCENTREX 5
