MICROTURN CUTS ARCS BACKWARDS
I have a microurn and am designing with LatheCAM Designer.
There is an arc that cuts 90 degrees from the center out to about 1/2" diameter in a clockwise direction.
When the machine trys to make the finishing cut it moves 270 degrees in a counter clockwise direction. :doh:
If it did not crash it woud then cut the part correctly.
I am sure I have to change a setting in a post file somewhere but cannot remember which one.
I was using the Mictoturn Imperial Post.
Please can you advise where the file is located and what needs to be changed.
Re: MICROTURN CUTS ARCS BACKWARDS
Thanks Graham!
This is what I needed.
I had looked in the Fanucl.ini because I had already edited the file extension to be FNL not FNC.
I just missed the bit below as I was looking for G02 and G03.
May be we should have a software section for MillCAM and LatheCAM? :?:
When is this INI file created? Is it when Lathecam is installed?
Is this fixed on the current version of LatheCAM?
Anyway the solution is below:
This way you will not have to manually change the G Codes. However in 2D/3D simulation it will be wrong, as the tool is coming in from the back side of the material.
Search for the fanucl.ini file and found in C:\Denford\Config.
Open the fanucl.ini file in Notepad and scroll down until you find CNC Lathe (inches) and add the lines
CWCode=3
CCWCode=2
Then scroll down farther until you find Microturn (inches) and add the lines
CWCode=3
CCWCode=2
Note:
If you have a Lathe that has a manual front cutting toolpost then the changes above need to be made.
If you are using a metric post they need to be set in Microturn Metric and Lathe Metric too
