Heidenhain control software v1.88 - helps with drip feed
JMini has kindly supplied v1.88 of the Heidenhain DOS control software:
https://www.denfordata.com/downloads/dos ... _v1_88.zip
He said:
Please find attached zip file. The only problem that I have found with this version is that when a Tool change is done the m/c goes to the tool change position the spindle start rotating
And then nothing else happens (non of the heidenhain keyboard buttons will have any effect)
So to get round the problem I have put “ATC 0” in the opt file and fitted a manual tool release Button (interlocked with spindle so the tool cant be released while spindle is running)
