Spindle not rotating- Vertical Router
when using the vertical router, the spindle is not switching on. I have tried to switch it on via the control panel but the dial icon is not showing. All other function of the machine are good, ie homing, moving x,y & z via a .fnc file. I have tried another machine 2600Pro and the software can be used to switch on the spindle manually. Is this a problem with the sensors or the motor? The switch on the head is ON.
Some suggestions from our service team:
Has the spindle pot been turned up to set a speed?
Does the guard lock activate when spindle turned on?
FS2 on the pcb is the fuse to check.
Also, does the spindle relay RL2 pull in when spindle on button is pressed?
No one has switched the Spindle motor off with the swicth on the motor itself have they ? :oops: :oops: :oops:
The carbon brushes in this motor are consumables, are they worn out ?
Part No BI00307MB
Here is the schematic and overview of spindle circuit.
The Fuse is FS2 and i think it should be a 10A F rated fuse.
vertical router schematic.jpg (338.41 KiB) Viewed 6440 times
vertical router spindle.jpg (20.03 KiB) Viewed 6440 times
