Micromill 2000 “Machine Error: Exceeding Limits
MicroMill 2000
S/N 56487
November 2001
Description of problem: I stopped the machine to oil it recently, and ever since then, each time I start to cut something I get a message that says: “Machine Error: Exceeding Limits.” I have tried changing cutting bits, made new designs, etc. and nothing seems to help correct this problem. Any ideas you can give me to correct this problem would be helpful.
What version of VR Milling are you using?
Click on the "Help" tab and select "About". The version will be listed.
Check or re-set the "Work Piece Offsets".
In VR Milling version 2, make sure there is a Red check mark in front of the "Active" offset.
Attached is a Tech Article on setting the Offsets in VR Milling version 2.
You can check the selected offsets by using the MDI (Manual Data Input) tab.
Click on the MDI tab and in the "White Box" type in
x0y0 (zeros) <enter>
z0
See attached jpg.
Then click on the Triangle "Start" button. The machine will move to Work Piece Offset that is "Active".
MDI Tab.jpg (45.99 KiB) Viewed 15136 times
Seemingly inexplicable move exceeds limits error messages are often caused by the Z tool length offset having been set my mistake..
Check the H value (next to the D value) in the control panel window, which is the active tool length offset.
(You'll see that its 0.000 in the above screenshot)
I performed all of the suggestions concerning offsets posted previously and still have not had any luck with correcting this problem. The version of software I am using is 2.8.2.492. Not exactly sure about the H and D values mentioned on the previous post. The program stops on the first Z line that says "Z0.08" Again any help provided is appreciated.
I do not have the MDI tab on this version, so cannot check the H and D values.
Update VRMilling to the latest version. The version you have is quite old. The latest version can be downloaded from the Denford website. You need to download VRMilling Ver 2.31. The version you have is Ver 2.08.
Before you update make sure you have the VRMilling licence floppy or a Denford Dongle with VRMilling set.
The download link is on this page:
I didn't realise you were using an old version...the new software will certainly help with your problems.
Have you tried running a project file that worked before you have had this problem?
Are there any "Details" listed in the "Exceeds Limits Error"?
Is the cutting tool set to high in the collet?
In the JOG Mode, are you able to lower the "Z" axis far enough so that the cutting tool will touch the piece of sacrifice material that you have the billet mounted to?
You may need to loosen the cutting tool and pull it out of the collet, OR go into to the "Machine Parameters" and increase the negative "(-)Z" travel.
OK, I downloaded version 2.31 and extracted the information. When I went to install it with my registration disk in the A: drive, I get a message that says that my disk is not formatted. I find this strange, because I just used it about a month ago to install the older version (2.08 ) when I got a newer computer to run the micromill. Any suggestions?
If you can get the file off the floppy on another machine and copy it to a flash pen, it can be installed from any drive (eg C: D: E: ).
See this info for how to install a flash code manually:
viewtopic.php?t=100
On your PC with the old installation of VR milling ver 2.08, go into C:\Program Files\Denford\VRMilling and locate the file WindMill.ini. Open this up with Notepad and make a back up of the 3 lines
[Flash]
Flash_User=XXXXXXXXXXXXX
Flash_Code=XXXXXXXXXXXXXX
Then cut and paste these 3 lines into WindMill.ini of your new VR Milling ver 2.31 installation
ALWAY MAKE A BACKUP OF YOUR LICENCE FILES AS WE CHARGE FOR REPLACEMENTS :lol: :lol: :lol:
I just wanted you to know that I was able to correct the problem using the newer version of the VR software. Thanks for all the help!
