Triac RS232 lead - Pin layout?
Hi, I am trying to run my 1984-5 Triac via BobCad/Cam on my PC but I do not have the required RS232 cable.
I have bought the connectors to make up a lead, and I am unsure of the pin layout.
Any one have any idea?
Thankyou
rs232 pinout
from the orac manual (should be the same as triac)
sec34 p102.jpg (36.29 KiB) Viewed 8195 times
25 years as Electronics design Engineer, cnc machines used for manufacture of prototypes. Have Boxford 240tcl and 260vmc, Denford starmill, used to have an Orac. All converted to run Mach3. Happy to try to help with any tech issues.
data
try also
https://www.denfordata.com/downloads/dos/triac.zip
this may help testing your 232 connection.
You may also find the manuals for the triac here, though I've not checked.
Hi Andy, thankyou for that info - but on the Triac it is a 7 pin DIN connector, and not the same as the Orac sadly.
Although I could have done with that info you gave me for a freinds Orac :D
triac 232
sorry for the missleading info!
In the manuals dowload section is the scanned manual for the triac- there are connection details there
https://www.denfordata.com/downloads/dos/manuals.zip
Thank you very much Andy - I think I've found what im looking for from your link.
