hi
i also have an Easiturn3 (PNC3 CONTROL) with the same problem, i manually moved away from datum/ref/zero, i have removed the saddle and checked the 2 limit (overtravel?) switches they are clean and working fine, i also checked the proximity detecter it had 4volts rising to 4.3 volts when activated.
i have even looked for a thermal trip on a relay but as yet have not found one
STILL unable to 'zero' therefore do anything else.
did you manage to sort out your problem.
any help in this matter greatly appreciated
regards barry (barry@oursdotcom.co.uk) (barry(at)oursdotcom(dot)co(dot)uk)
