Post processors for current (06/07) Denford software
The current Denford software uses a fairly simple post processor configuration file.
These files are used by:
  • QuickCAM PRO
    QuickCAM 3D v3
    QuickCAM 2D Design
There is enough flexibility to allow output to most CNC machine manufacturers
As of today 26th Jan 2007, the current latest software ships with the following posts....
  • Boxford V10.ppl
    Denford (Inch).ppl
    Denford (Metric).ppl
    eduCAM.ppl
    Larken Camtool Router.ppl
    Pacer.ppl
    Roland Modela.ppl
    Roland.ppl
    Triac PNC.ppl
As other manufacturers change their software, and our limited ability to test these posts on all variations, it may be that you have problems getting them to work.
If you do, then don't despair - please post a message on here and we will help you reconfigure the post file.
A new post processor file has been added to allow our software to create G Code for the Techno machines
techno-g-code.ppl
Download the above file, and put it into this directory:
C:\Documents and Settings\All Users\Application Data\Denford\Posts
Proof that it works...
An F1 car toolpath produced by Denford QuickCAM Pro being previewed in G Code Interface for Davinci and C-series (Techno Inc)
Hi guys,
I have noticed that you have a post for Roland Modela machines. Do you know if this post would work for the MDX range, or would this require a whole new post for the MDX range? We have some schools who have both a denford machine and roland machines and are asking this question.
Paul Wilson
We don't have much experience of Roland machines here, so its really down to the customer to help us work out how the file structure works.
I believe that the files we currently create through the Roland post need to be sent via some additional Roland downloading software :?
I really aren't sure how you machine files on Roland machines, so if anyone can enlighten us, then I'm sure we will be able to create the necessary machining file for any Roland.
Techno Post
Denford Admin wrote:A new post processor file has been added to allow our software to create G Code for the Techno machines
techno-g-code.ppl
Will this post work with VR Milling 5?
HITech is the Exclusive Denford Dealer for Pennyslvania & New York.
Brian Haskell is the former National Sales Manager for Denford from 1994-2003.
Unfortunately the post output in VR Milling 5 only creates the old format .GNC files for use with the old post processor
What would you want it to come out of V5 milling for ?
In order to use the dxf or gerber wizard ?
If so, you should be looking at QuickCAM 2D to do the same thing.
Or do you want to convert existing programs (.fnc) into other formats ?
Techno Post
Customer wants to use VR Milling to simulate program, work with tooling before posting to Techno. They like Denford graphics!
Ok - sorry it can't do that at this time.
I can see if it could be added !
Compact 1000 - Ran bit into jig
Customer asks --- we have a Pro-light 1000 mill and I was wondering how or if it is possible to insert the Prolight 1000 post into the software so we could use it with the one seat of Quickcam PRO that we own.
Please advise if one of the posts currently available, did not see above unless identified under an alias. Thank you.
Its definately possible - all we need is an example program that works on the pro-light.
Some idea of what the program is / sizes etc... would also be good.
We just then need a willing guinea pig to try it out on their machine
post processor
Customer writes:
Prolight 1000 program attached - Find a NC file of a contour cut on a 1.5"X2"X3" block, and a word document of the codes with a screen capture of the design.
contour2 (2).zip
(3.76 KiB) Downloaded 1647 times
Contour Block.doc
(116.5 KiB) Downloaded 2471 times
After a quick look at the program, I think the Larken Camtool Router.ppl will already work on the Pro-Light machine.
Give it a try and we can make some tweaks if required.
Then we can create a new post file, based on the Larken one.
Larken Camtool Route Post
Can not fing your Larken Camtool Route Post
Mark
Mark Hines
Then you must download and install the latest version, find it here:
Not sure when it was added, but its definately included in the latest version(s).
There is no point trying the post file on its own, there may have been changes done to make new post files work properly from within the software.
Surfcam and Micromill 2000
We are using Surfcam and would like to have the Micromill 2000 read the out put file and manufacture our design.
To work with the Micromill 2000 - the post is already available in Surfcam --- it is Surfcam std 6m post
Re: Post processors for current (06/07) Denford software
hi denford, i was wondering if you could send more information about QuickCAM.... because i really need it !! thanks a lot good luck bye ;)
  • QuickCAM PRO
    QuickCAM 3D v3
    QuickCAM 2D Design
Bulldog UK - Sheet metal machinery supplier
