Flats machined on circular cuts on Microrouter
When I draw a circle in Techsoft and try to cut it out on a Microrouter (Anticlockwise cutting) i get flats machined at 2 and 8 O'Clock on the circle
The answer to this will be caused by Backlash. Solution / things to check
1. Is the "X" axis "Crabbing"?
2. Ensure the "X" axis pullies are aligned
3. Check the locknut on the "X" axis is tight
4. Check that the lead screw bearing securing plates are secure
5. Clean the "X" axis anti backlash units
6. Clean the "X" axis guide bars and lead screw and lubricate with dry
silicone
[quote="bradders"]The answer to this will be caused by Backlash. Solution / things to check
silicon
7. Coupling could be broken
