Does anyone know the sensor details for Easimill PNC axis sensors, NPN or PNP, 2 or 3 wire, Voltage etc
    				    			I can give you a starter for 10 - they're 2 wire if the Easiturn is anything to go by...
I'll have a look see if I've still got the original ones...
www.la-coterie.com
    				    			www.la-coterie.com
You're in luck!  I found one and stuck it on my RS proximity switch tester and it seems to indicate that it's PNP (assuming I connected the 2 wires in the right place
 (I'm not an electronics guru but I know what an electrolictic capacitor looks like - even if I can't spell it
Voltage? dunno but it works with the RS thingy which uses 9v....
any use?
any use?
www.la-coterie.com
    				    			www.la-coterie.com
Cheers Triac Whizz, after a lot of searching I found some in stock (BI00401A) and you are right they are 2 wire devices
No worries, i see you have one of those dsylexic keyboardsCheers Traic Whizz
Good job you didn't print the stickers for the machines
you can call me TW
www.la-coterie.com
    				    			www.la-coterie.com
