Circular interpolation in the z plane
We are trying circular interpolation in the z plane. We have programmed using G19 and it works in the software. Also we tried programming by using cirular int. and z values. Both of the look good in the program but when we run on the TRIAC mill it won't do it. Any suggestions?
Thanks,
Jess
I'm pretty sure G18 and G19 only works fully on the latest control cards which are the NextMove ST (with the green seven segment displays) along with VR Milling V5.
You could try setting the expand Arcs to Lines option in parameters in VR Milling v5.xx this will break arcs and helicals into lots of small linears.
Also, make sure you have the latest version from our website www.denford.co.uk - Technical Support page
Seem to think there was something in Version 2 VR Milling as well.
