How to change the tooling and offset file location - v5
How do I change the location of the alloffsets.mof file from its default location in VR Milling version v5 ?
Some networks are restricted and will not allow the default file to be edited...
Open the work offset editor - the Offsets / Tooling menu should now appear on the top menu bar as shown.
Select the option "Save As..." and save the offsets file to a location on the network, which you have read / write permissions
Now, to make VR Milling use this file, select the "Advanced" menu option and click "Load All" which will have now appeared....
Now choose the .MOF file you saved previously
