poor simulation graphics in V5
In my old version 2.32 the graphics in both 2d and 3d simulation are sharp and clear but when running the same programs in version 5.17 the graphics are very poor and blurred. I am using the same computer with both versions so I dont think it can be a graphics card issue.
Paul
Sorted now. I found the setting in the billet setup that allows you to change the resolution..
The billet resolution setting allows you to improve the graphics at the cost of speed. If you design a large componet the graphic resolution may change also.
As a general tip the top menu bar changes as yo select different windows and any settings relative to the active window are displayed.
For example when working in the offsets and datum window there are options available to backup or save the current settings.
These menus are only available when the window is active.
Mr Magoo, Martin, Steve
