Starturn 4 control software errors
Hi Guys
We received 5 denfords as a donation
2- 86 triacs
2- 85 oracs,atc
1- 87 starturn,atc
Orac is up and running, still trying to find a post that the machine can read.
The Startun came with a ISA control card (precision stepper motor control er, Quickstep-PC) We didn't install the card because we cant find a PC with an ISA slot. Tried running the Fanucsld software and get the 128 error code. Starturn offline software gives the error Software file cant be found or corrupted. OS is dos.
any help would be appreciated
looks like there is 2 versions of the Starturn software 1 gives error but other works. it hangs, guess it cant see the machine.
This could be why the fanucsld wont run either.
Hi dwynkoop
Denford never used an ISA QuickStep control card on their Starturns so I guess your machine must have had a retrofit upgrade at some point (or perhaps the cards don't belong with the machines and are a red herring???)
Both Starturn and FANCUSLD software communicate with the machine via RS232, a 'normal' Starturn machine having it's own intelligent controller built into the electrics.
Hope this gives you some clues!!! (but I don't hold out much hope for these :(
finally got it to work, it was the version of software and the cable.
Oh, I have the complete manual for the Triacs. Im slowly scanning them into pdf. If anyone needs a certain section let me know.
Thats very kind of you :D
There is a guy asking about the ATC connection details (to the 15pin connector at the back ?)
viewtopic.php?t=875
I found some original working drawings and put them in the Download section , but maybe you're manual is clearer ?
I dont have a atc, but here is the auxiliary input page. Its the same as your link, but has all the pins.
triac 11.jpg (87.62 KiB) Viewed 8468 times
