Guest
Techsoft 2D design on RM CC3 networks - WINEXEC FAILED
I get the message “WINEXEC FAILED” when running Techsoft on a RM CC3 network
You Must tick legacy applications in the RM stuff - otherwise get winexec failed memory low error when trying to plot to Denford machines. This is because there are some 16-bit applications / DLLs
This error message may also appear when the InstallShield setup.exe program is executed over a network. Copy all the files on the distribution disk to a local folder and run setup.exe from this folder.
