Seeking lubrication clarity
In the VMC 1300 Pro CNC Milling Machine User’s Manual
Page 41
12: Lubrication Chart says:
Machine Ballscrews with grease gun Every 3 Months
Machine Slideways Every 6 Months
Axis Bearings Apply by Syringe Every 12 Months
Then there are photos pointing out for example, Four lubrication points for the "X axis bearings" and one point for the X axis ballscrew are located at the sides of the machine saddle.
This is a bit confusing, because of the term "X axis bearings". I assume the photos showing the X axis lubrication points above are pointing out the one Machine Ballscrew and the four Machine Slideways per the table, and that the "axis bearings" that should be lubricated every 12 months are rotating bearings somewhere else.
thanks!
Re: Seeking lubrication clarity
Its not easy to see so took some photos from machine assemblies. The bearings are in the same place by the motor mounts.
Thanks Steve. So there is one "axis rotary bearing" per axis and it's an unshielded ball bearing at the far end of the mount from each axis motor. That should be a fun task to access those with a syringe!
They will be packed from new and will probably last for years without lubrication.
Belated update on lubrication of axis screws rotary bearings. I used a syringe on 3 bearings, the X right you can see in the pictures is sealed so I left it alone.
X Right.jpg (49.5 KiB) Viewed 12242 times
X Left.jpg (46.36 KiB) Viewed 12242 times
What is the lubrication schedule for a VMC 1300 fitted with the optional automatic lubrication system?
The X/Y/Z linear guideway blocks have attached oil reservoirs, and I can follow the linear guideway manufacturer's recommendations.
The X & Y ballscrew nuts are plumbed to tubing with open ends secured next to the Y-axis microswitch, under the saddle. To lubricate the ballscrew nuts, would I inject grease into this tubing with a syringe?
