Tool tip angle stored incorrectly in Imperial mode.
MAX THE MILLER
Hardware/Software: Denford Triac PC. VR Milling 5.51.0.616
Post by MAX THE MILLER » Mon 07 Nov , 2022 11:24 am
Open QT2DD
Click options
Click Machine Options
Select Imperial
Click OK
Click options
Select Machine Tooling
Select a tool.
Change the tip angle say from 65deg to 55deg
Click OK in tool window
Click OK at bottom of the page
Click options
Select the tool whose tip angle has just been changed.
Value is shown is tool angle in degrees multiplied by 25.4 ie 1397 for 55deg and 1651 for 65deg.
Re: Tool tip angle stored incorrectly in Imperial mode.
Post by Denford Admin » Wed 09 Nov , 2022 11:54 am
Thankyou for that excellent writeup of how to repeat the issue. We're looking to fix this at the moment.
Post by Denford Admin » Fri 02 Dec , 2022 14:28 pm
There is a new version released, V1.35, which keeps the angle value of tools regardless of the measurement type. We'll look at the import conversion issue next.
MAX THE MILLER
Post by MAX THE MILLER » Thu 05 Jan , 2023 16:12 pm
Sorry, but I missed the last post.
I've now loaded Version 1.35 and can confirm that the tip angle is now stored correctly.
Many thanks, Max.
