Alphacam post for Denford Cyclone
Hi all does anyone know if there is a Alphacam post for for a Cyclone lathe. I have just purchased this machine so all a bit new to me mostly ese cnc routers. Thanks
cyclone lathe plate.jpg (124.91 KiB) Viewed 17837 times
cyclone lathe.jpg (101.13 KiB) Viewed 17837 times
Re: Alphacam post for Denford Cyclone
The Fanuc 15,18 or 21 post should work fine.
Hi thanks for the reply, what about the 6Tpost would that work?
I will work as long as you do not use the canned cycles in Alphacam, The 6T post is single line canned cycles, the 0i,15 18i and 21i are all 2 line canned cycles unless you have the F15 option installed in the control.
