DOS and VR EPROM Versions
Here is a list of the EPROM numbers fitted to the Smartstep, Denstep and Nextstep controller cards.
All the machines were supplied with DOS software before 2000 and a change over to the current VR Turning and VR Milling software in late 2000.
To identify what software will run on your controller you can simply check the version of the EPROM fitted to the control card.
If you have a DOS EPROM then you cannot use the latest VR Software without replacing the EPROM
DOS AND VR EPROM VERSION NUMBERS.pdf
(7.12 KiB) Downloaded 1946 times
Re: DOS and VR EPROM Versions
EPROM LOCATION NEXT STEP CARD
EPROM LOCATION SMART STEP CARD
SMARTSTEP EPROM.jpg (218.83 KiB) Viewed 23641 times
