'Invalid image format" error
I get a 'Invalid image format" when trying to install VrR Milling Ver 2.** on a lap top running Windows XP Professional
This would mean that you have selected the wrong machine to connect to in vr milling.
check main title bar of window says: Virtual Reality CNC Milling - MyMachineTypeNS
Try changing the control type if the machine type is definitely correct - (Menu:Setup Machine Parameters - denny, Communications) either from 7 to 9 or vice versa
