Fanuc 21i-M - Fully backed up and working without issue - Battery back up completed in Jan 2020
Manufacture date October 2003 - total run hours 170 from new!!
All set up for RS232 with DNC software (inc full paid license) along with Panasonic Toughbook touch screen WIN10 PC included
8 station BT30 ATC all working perfectly
Open & close guarding working perfectly with M codes
4000rpm standard spindle
All pneumatic valves changed & upgraded to SMC units at a cost of £700 (as originals had typical dried out seal problems)
Working on single phase - Was 3 phase from factory but previous owner converted it to 240v
Hydraulic Vice complete & working with M codes
Linear rails as standard from factory on all axis
All original documentation from factory - manuals etc
Upgraded IP68 internal LED strip light (original light still in place)
6 off BT30 ER16 holders - nearly new
5 off BT30 ER32 holders - nearly new
1 off BT30 quick change drill chuck - nearly new
1 off BT30 face mill adaptor - nearly new
1 off fixture plate for additional clamping area with fixing holes
Suds pump working off switch rather than through M8 code
630 kgs so can be moved with a pallet truck
Is under power & air so can be demonstrated without issue - located in Worcester
Very nice working machine - does have some age related marks externally
I've owned this since Jan this year and has produced some really nice work - Just purchased a machine with bigger capacity so not using it, seems a shame to have it standing idle so hopefully it can go to a good home.
Price £5,000
Any further detail please ask & I can add some pictures soon hopefully
