Removing the 4th Axis
Just picked up a microrouter Compact 2005.
Has a fourth axis attachment I wish to remove,any advice or documnetation for the correct procedure involved.
Thanks,
Brian
Re: Removing the 4th Axis
Forget it,
Got it sorted a very straightforward twist and slide.....a previous post involving cut wires had me spooked!
Glad it's sorted.
As an add on after the removal I came into an error indicting 0% federate.
This was solved by going into setup machin parameters and unticking the “federate pot” option
FYI passwords “denny”!
