If you are struggling to configure EdgeCAM for use with a Denford machine, try this Denford EdgeCAM post processer file:
files/denford_125.mcp
EdgeCAM Denford Post Processor File
- Hardware/Software: I have Harrison M250 with Anilam control +Bridgeport interact 1 with Heidenhain 407
just bought Denford Quatro with North East Electronics Control, and I use Edgecam for Programming - Location: Treforest South Wales
Re: EdgeCAM Denford Post Processor File
This web address returns an error in windows 7 regarding file association, is there a format you can send it in that will open in EDGECAM please
Regards Blakey
Regards Blakey
I've attached it as a .zip file:
- denford_125.zip
- (20.59 KiB) Downloaded 1644 times
Have opened zip file OK, but appears to be in machine code, does it have to be opened in EdgeCAM?
Yes I'm pretty sure you'll have to open the file with EdgeCAM or place it into the correct directory (something like: C:\Program Files\EdgeCAM\Machdef - wherever the other post .mcp files are)
This worked great for me, thanks so much
