ML drawings for 5" TDS1 lathes
ML100 ML105 ML110 ML115 A4 drawings scanned
Here are a lot of drawings for the smaller bits of Viceroy Lathes
ML115 drawings -
List of drawings: and the drawing file:
https://www.denfordata.com/downloads/for ... 0scans.pdf (13Mb)
ML100 & ML105 drawings -
https://www.denfordata.com/downloads/for ... 0scans.pdf (20Mb)
ML105 & ML110 drawings -
https://www.denfordata.com/downloads/for ... 0scans.pdf (17Mb)
BVS and MVS parts lists have been moved here: viewtopic.php?f=50&t=2960&p=10536#p10536
ML115 drawings -
Re: ML100 ML105 ML110 ML115 A4 drawings scanned
End drive (Change Wheel) Arrangement for Metric TDS 1/1 lathes (non-gearbox)
- ML105_100C (CAD).pdf
- End drive (non-gearbox)
- (175.17 KiB) Downloaded 1377 times
Stud gears A-G for metric gearbox lathes.
- ML 115 metric gearbox stud gears a to g.pdf
- (2.34 MiB) Downloaded 1386 times
Re: ML drawings for 5" TDS1 lathes
Nose thread and register data for 5" lathes (screw-on chucks)
- ML_NOSEDATA.pdf
- 1 1/2" x 8TPI thread data
- (144.8 KiB) Downloaded 1272 times
Thanks for the nose thread data Andy, that's a very handy reference to have.
4 drawings for cross-slide leadscrews - ML110/501A (English) and ML110/501B (Metric), ML100/514A (English) and ML100/514B (Metric).
Plus a drawing for the leadscrew nuts (3 different versions)
Edited to add further drawings.
- ML100-514B.PDF
- ML100/514B
- (89.89 KiB) Downloaded 1261 times
- ML100-514A.PDF
- ML100/514A
- (91.79 KiB) Downloaded 1280 times
- ML100_512 bw.pdf
- ML100/512 Cross slide nuts
- (49.2 KiB) Downloaded 2836 times
- ML110-501B.PDF
- ML110/501B
- (109.79 KiB) Downloaded 1265 times
- ML110-501A.PDF
- ML110/501A
- (94.13 KiB) Downloaded 1194 times
Drawings for Leadscrews:
ML105/402 - Std 24" Imperial
ML105/402B - Long version (for 52"bed) Imperial
ML105/402C - Std 24" Metric
ML105/402D - Long version (for 52" bed) Metric
and the Bed Arrangement that shows these parts installed:
ML105/400
Edited to correct file comments.
ML105/400
- ML105-400 5in S-C & Plain Lathes - Bed Arrangement.pdf
- Bed Arrangement
- (319.16 KiB) Downloaded 1060 times
- ML105-402D.PDF
- Long Metric Leadscrew
- (103.07 KiB) Downloaded 1058 times
- ML105-402C.PDF
- Std Metric Leadscrew
- (106.48 KiB) Downloaded 1029 times
- ML105-402B.PDF
- Long Imperial Leadscrew
- (71.37 KiB) Downloaded 1009 times
- ML105-402.PDF
- Std Imperial Leadscrew
- (96.17 KiB) Downloaded 1093 times
I knew you'd have the answer Andy!
How are you getting on with the Synchro, did you ever do the translation gears?
Richard Wilson
Richard Wilson
Toolpost drawings
- ML119-1B.PDF
- 4-Way Toolpost (5.5")
- (100.48 KiB) Downloaded 1046 times
- ML119-1A.PDF
- 4-Way Toolpost (5")
- (106.18 KiB) Downloaded 1035 times
- ML119.PDF
- 2- & 4-Way Toolpost Arrangement
- (83.18 KiB) Downloaded 1051 times
- ML100-801B.PDF
- 2-way toolpost VS Lathes (5.5")
- (106.75 KiB) Downloaded 985 times
- ML100-801A.PDF
- 2-Way Toolpost (5" Lathes)
- (107.24 KiB) Downloaded 981 times
- ML100-801.PDF
- Tool Post Base (Single Sided)
- (78.34 KiB) Downloaded 1071 times
- ML100-800.PDF
- Toolpost Arrangement (Single sided)
- (46.05 KiB) Downloaded 1028 times
... and an oddity..
It's numbering is part of the toolpost drawings... and looks like some tooling associated with their manufacture.
- ML119-2A.PDF
- Milling fixture
- (106.79 KiB) Downloaded 997 times
More drawings of small parts used on the 5" lathes, with some also carried over to the 280's
ML100/103 99T Sliding Gear 5in Viceroy Metal Lathe
ML100/144 Oilite Bush for 68T Gear 5in Viceroy Metal Lathe
ML100/111A Locknut 5in Metal Lathe
ML106/1 Cross Slide Thread Cutting Stop 5in & 280VS Lathes
ML100/118 Gear Shifter Shaft 5in Viceroy Metal Lathe
ML100/108A 38T Driving Gear 5in Viceroy Metal Lathe
ML100/111 Locknut (Special) 1-off
ML100/114 Eccentric 5in Viceroy Metal Lathe
ML100/131 Front Nose Cap 5in Viceroy Metal Lathe
ML100/132 Driving Pulley Plunger 5in Viceroy Metal Lathe
ML100/142 Lo Vo Light Fitting 5in Viceroy Metal Lathe
File:
File:
- ML100 parts #1.pdf
- Various ML100 drawings
- (1.24 MiB) Downloaded 1021 times
Another batch of ML part drawings (with a couple of 'US' numbers (whatever they are?)):
US100/305 Apron Eccentric Old Type 5in Viceroy Screwcutting Lathe
US100/305A&B Apron Driving Gear & Pinion (Old Type) 5in Viceroy Metal Lathes
ML100/202 Levelling Screw 5in Metal Turning Lathe
ML100/205 Cabinet Drain Plug 5in Viceroy Metal Lathe
ML100/208 Coolant Connecting Pipe 5in Viceroy Metal Lathes
ML100/208A Coolant Pipe 5in Viceroy Metal Lathe
ML100/210 Coolant Pump Motor Pulley 5in Viceroy Metal Lathe
ML100/211 Coolant Pump Pulley 5in Viceroy Metal Lathe
ML100/214 Coolant Connecting Block 5in Viceroy Metal Lathe
ML100/215 Reversing Switch Handle 5in Viceroy Metal Lathes
ML100/219 Coolant Drain Guard 5in Viceroy Metal Lathe
ML100/219 Coolant Drain Filter 280VS Bench Lathe
ML100/305A Apron Pinion (Dated 1968) 5in Metal Turning Lathe
ML100/305A Apron Pinion (Dated 1964) 5in Metal Turning Lathe
ML100/306 Handwheel Pinion (Dated 1963) 5in Viceroy Metal Lathe
ML100/306 Handwheel Pinion (Dated 1965) 5in Viceroy Metal Lathe
ML100/308 Apron Handwheel Handle 5in Viceroy Metal Lathes
ML100/310 Handle Support 5in Viceroy Metal Lathe
ML100/404 Bed Tenon 5in Viceroy Metal Lathes
ML100/406 Extended Fixing Screw For All Types. Gear Box
ML100/407 Extended Fixing Screw For All Types. Gear Box
Drawings file:
Drawings file:
And another, ML100/5xx numbers this time:
ML100/505B 3 Ball Handle – Knob 5in Viceroy Metal Lathe
ML100/506 Locking Pad [with 1967 Mod] 5in Viceroy Metal Lathe
ML100/506 Locking Pad [1961 Original] 5in Viceroy Metal Lathe
ML100/510 Leadscrew Bush [1961 Original] 5in Viceroy Metal Lathe
ML100/510 Leadscrew Bush [1965 et seq. Mods] 5in Viceroy Metal Lathe
ML100/511 Feed Nut 5in Metal Turning Lathe
ML100/511A Top Slide Feed Nut (English) 5in Viceroy Metal Lathes
ML100/511A Top Slide Feed Nut (English) [1973 Mod] 5in Viceroy Metal Lathes
ML100/511B Top Slide Feed Nut (Metric) 5in Viceroy Metal Lathes
ML100/511B Top Slide Feed Nut (Metric) [1973 Mod] 5in Viceroy Metal Lathes
ML100/512 Feed Nut PCS Lathe Cross Slide Unit
ML100/512A Feed Nut (English) 5in Viceroy Metal Lathe
ML100/512B Feed Nut (Metric) 5in Viceroy Metal Lathe
ML100/512C Feed Nut (English) 5in Viceroy Metal Lathe
ML100/512D Feed Nut (Metric) 5in Viceroy Metal Lathe
ML100/513 Saddle Leadscrew Bush (English) 5in Viceroy PCS Lathe
ML100/513E Saddle Leadscrew Bush (English) 5in Viceroy Metal Lathe
ML100/513 Saddle Leadscrew Bush (English) [Mods] PCS Lathe Saddle Unit
ML100/513 Saddle Leadscrew Bush (English) [Original]5in Viceroy PCS Lathe
ML100/514 Cross Slide Leadscrew 5in Viceroy Metal Lathe
ML100/515 Top & Cross Slide Bearing Collar 5in Viceroy Metal Lathe
ML100/516 3 Ball Handle [1965] 5in Viceroy Metal Lathe
ML100/516 3 Ball Handle [1958] 5in Viceroy Educator
ML100/520 Top & Cross Slide Dial 5in Viceroy Metal Lathe
ML100/520A Top & Cross Slide Dial (ENG) [1978] Viceroy Metal Lathe
ML100/520A Top & Cross Slide Dial (ENG) [1965] 5in Viceroy Metal Lathe
ML100/520B Top & Cross Slide Dial (Metric) [1971] 5in Viceroy Metal Lathe
ML100/520B Top & Cross Slide Dial (Metric) [1978] Viceroy Metal Lathe
Drawings file:
Drawings file:
Thanks Andy especially for that last one.
Actually I've found what I think is an error in one of the drawings.
In ML100/512C FEED NUT ENGLISH the thread form is given as 1/2" x 10tpi modified square thread (LH). This is obviously the cross slide nut but in the drawing for the cross slide screw ML100/514 the thread form is given as 1/2" dia x 10tpi (LH) ACME FORM (as you'd expect). The metric nuts are usually modified square section but I think that the nut thread for the English nut here is mis-labeled and should actually be ACME, like it's mating screw, not modified square thread.
Hello, I have a 1984 Viceroy 280 Synchro with the 8 position imperial gearbox, does anybody have drawings for this lathe? I am trying to determine what size the stud gear should be.
I don't *know* the answer and I can't find a specific drawing but if you look at my post further up "Stud gears A-G for metric gearbox lathes" you'll see that the 24 tooth "D" letter gear is annotated differently to the rest of the set of 7. It doesn't specifically say 'metric' like the other 6 and includes the text 'special stud gear for reversing bracket' which the others don't include.
Added to that Page 13 of the replacement parts list shows the stud gears as 42 and 24 teeth. 42T must be the gear that meshes with the pair of 32 tooth reversing idlers and the 24T is the first driver for the end train I guess. The drawing number in the parts list also matches the stud gear 'd' drawing number ML115/948.
Pretty sure it's that one - 24Teeth, 16DP, 20PA
As far as I can tell, if its an imperial lathe with the 8 position gearbox, and you are using it to cut imperial threads, that stud gear should be 24T, drg No. ML.115/948.
Richard
Richard
Thanks for the replies, I suspected the stud gear should be 24 teeth but reassuring to have confirmation. Now I have to find one!
ML124 Splash Guards
Please don't add comments in this thread - it makes it harder for people to find stuff.Andy
