ilbiondo
- CNC Apprentice
- Hardware/Software: VMC TRIAC with ATC
Post
by ilbiondo » Fri 13 Apr , 2012 15:59 pm
Hi, I'm still here...
Ok, the machine works and I have already done some work but when I turn off and turn on does not keep in memory the tool and I have to reset with M27 (RESET CAROUSEL TO POCKET ONE).
The problem was there before the break of Baldor card.
Any ideas?
Thanks again.
Post
by Denford Admin » Tue 17 Apr , 2012 8:42 am
I'm not 100% sure that the DOS software stores the carousel position...
If it did, then it will probably in the none-volotile memory of the Baldor control board (like it is now, on the modern machines)
So that would suggest the battery has also failed on the new board - I'd try replacing it again.
If you don't want to try that then maybe you can get into the habit of calling tool 1 before powering off everytime
Post
by Martin » Tue 17 Apr , 2012 11:15 am
On some of the machines we used to fit a dongle to the printer port on the control pc which saved the tool position.
ilbiondo
- CNC Apprentice
Post
by ilbiondo » Wed 18 Apr , 2012 15:08 pm
Interesting! Can you give me instructions for doing so?
david
- Hardware/Software: Hi,
I have faulty baldor D281 motion control card for a triac P. C. (denford). The firmware is ESMINT 3.28 V1.6H/S - JD5. We would like to purchase this card, is it still available? Please let me know as soon as possible, I need it urgently for students' semester projects.
Thank you.
Post
by david » Thu 17 Nov , 2016 12:04 pm
Thank you.
Post
by bradders » Thu 17 Nov , 2016 12:12 pm
Unfortunately these boards are no longer available
moray
- Hardware/Software: Triac VMC
Post
by moray » Sun 20 Nov , 2016 12:25 pm
david wrote:Hi,
Thank you.
David,
If you're still looking, I've just removed a complete rack from a 1994 Triac VMC.
The board has a red 7-segment display and the chip has ESMINT/3.28V1.6G B1/S-JD3 on it, however from what I gather you can just change the chip.
I have no idea if it works, but it was powering up before I removed it.
Everything is listed in the classifieds -
https://denfordata.com/bb/viewtopic.php?f=13&t=5221
david
Thank you.
Post
by david » Sun 20 Nov , 2016 20:38 pm
Hello moray,
How do I make payment? Thanks.
David
david
Thank you.
Post
by david » Tue 06 Dec , 2016 14:40 pm
Hi Moray,
Hello, I have not heard from you for quite sometime. I hope all is well. Thanks
Regards,
David.
david
Thank you.
Post
by david » Tue 10 Jan , 2017 12:13 pm
Denford Admin wrote:We have this card spare:
However, we cannot test it here (so can't guarantee it is working) but it came from a working machine a few years ago.
Cost is £150 GBP + £5 airmail postage
Delivery by UPS will be more like £40GBP
You can pay via paypal from the donate button on here.
Hi, is this still available?
david
Thank you.
Post
by david » Tue 10 Jan , 2017 12:14 pm
david wrote:Hi Moray,
Regards,
David.
Hello Moray, happy new year! I have not heard from you for quite a while. Hope you are good.
