Viceroy Sharpedge TDS 12 / 16
Hello,
My Sharpedge is showing signs of wear on the main bush at the top of the gearbox, does anybody know if they are available?
A long shot I know but....
Thanks , Merlin
Re: Viceroy Sharpedge TDS 12 / 16
Hi Merlin,
I think it's very unlikely that you'll find a spare - but hopefully there is a drawing of it showing the original dimensions.
Have you found a part / drawing number yet - either in a spares diagram or assembly drawing / parts list?
Hello Andy,
I cant find a diagram of the part, the nearest is a ref no for the gearbox drawing that I have not got, the ref no is DRG SH5008A .
Do you know if that is listed anywhere ?
I suppose I could remove the bush and get one made but I thought I would ask first.
Thanks for your fast response.
Cheers, Merlin
Merlin,
I may have found the answer for you - see this post.
Looks like it could be a standard Oilite bush after all -available from any good bearing supplier.
Hello Andy,
I have just rebuilt the Sharpedge and it is now wobble free !
In the end I had some new bushes made as the old ones were passed it, I might look into buying some off the shelf ones for the future.
It still cuts square on the plane side but not on the chisel side ( I made up a template for the chisel side ) its not a big deal as you need to set them up any way.
Thanks for your help, Merlin
