Denford senior 200 parameters
Hi Everyone
I have just purchased a Denford senior 200 with fanuc ot control built 1990. Would anyone happen to have the original parameters for this machine. I have been told that because the machine has not been used that the battery may have gone flat and lost its setting?
Many Thanks
Michael
Re: Denford senior 200 parameters
Have you got the serial number?
Hi There
Thanks for your reply. Its a Denford senior 200 1990 with 8 station turret. I am not picking the machine up until Saturday so will be able to provide a serial number then if needed. Are the parameters different between serial numbers? I thought that model would all be the same??
Mick
The 900 Parameters & 450 Diagnostics may be different depending on options.
I have attached a copy of a set for the Marl machine.
MARL.zip
(2.56 KiB) Downloaded 973 times
