reference procedure to zero axis
Denford Cyclone with Fanuc 2li control. It has a switch on the machine bed and I have asked Denford to confirm if this is a reference switch or an over travel switch. The battery alarm came on and despite changing the battery it triggered a 300 alarm and now requires the x and z axis to be referenced. Denford have supplied me with the proceedure to change the relevant parameters but it makes reference to a "datum position". Does anyone know what this is or has carried out this procedure? Any help would be appreciated.
Re: reference procedure to zero axis
Yes. They will be home switches so all you need to do is replace the APC batteries on both drives then power up & home both axis to clear the alarms.
I have replaced the batteries but where do I position the drives to zero them? Do I have to manually drive them untill they hit the switches then change the parameters?
You don't need to do anything with the parameters. Just press & hold in the X & Z buttons until the axis has homed out.
If you mean the X+, X-,Z+ and Z- buttons then nothing happens. All I get is the EMG flashing on the screen.
Restarted machine again and it rehomed!!!!!!!!!! Many thanks for your help
