Denford Cyclone Wiring
Hi, i have bought a Cyclone. i am after some initial basic information about wiring up (there will be more to follow)?
The machine details are as follows:-
Serial number :-50911D
Dispatch date :- October 1995
Electrics Serial number:- OC0015002
Software version 1.34
I seems to be in near perfect original condition. So assuming untampered with.
There is a single armoured cable coming out of the machine containing a Yellow/Green, Brown, Blue and 2 black wires. Question. Is the machine fitted with a 3 phase inverter or do I need to provide the 3 phase supply?
Re: Denford Cyclone Wiring
Here is the original electrical inspection sheet.
It was 3 phase originally but someone may have fitted a single phase > 3 phase converter...you'll have to follow the mains wires.
50911D.pdf
(32.78 KiB) Downloaded 1344 times
I am being told that i will need the original machine set up. Datum parameters due to the time the machine has been disconnected. Is this the case?
The datum parameters are somthing you can set once the machine is running. Is the computer attached to the machine still working?
