2600 Pro keeps stopping!
The router has been playing up for some time with various incarnations of a similar problem.
When I go to run a program on the router the spindle will start and the head will move over to start cutting, sometime the machine will rapid down towards the job and then the side machine control window on the PC will just disappear. The spindle will continue to run but the PC and router have lost communication. Once this happens I cannot close the VR milling software and have to use the task manager to "End Task" and then it generates an error report which I send. Other times the router will run and some way through the program it will generate a "Device Cal has Failed" error message, sometimes the machine will continued to run and finish the program even though this error message is displayed and sometimes it will just stop!
I have updated the VR Milling software to the latest version, reinstalled it several times, checked everything using your Easy Upgrader software and still this problem persist. The machine is currently un usable!
Please Help!
Re: 2600 Pro keeps stopping!
Can you post a photo of the inside of the electrical cabinet ?
I think this is related to electrical noise when the spindle starts up.
Do you have a floating head attachment? Does that cause similar issues when that's being used ?
If you can take the M03 spindle start commands out of the program and try dry-running again it will prove there is an issue with the Spindle motor or Drive if programs run normally without the spindle running.
Hi. Thanks for quick reply.
Please find attached a photo of the electrical cabinet as requested.
No we do not have a floating head fitted to our machine.
I successfully did a dry run of a program with the M03 code taken out yesterday.
This morning I turned on and homed the machine and did some rapid jog moves ok, I then manually started the spindle and the "Device Cal has failed" error appeared. I think your assessment of noise could be correct.
How can we fix this please?
Rich.
NSSC pictures 44462 CB.JPG (277.34 KiB) Viewed 28695 times
Correction - The error message that is actualy displayed reads "The Device Driver Call Failed" if this helps. There is no error code number generated.
Rich.
As Admin suggests the PC is loosing communication and this is most likely caused by electrical noise when the spindle starts.
There are a few things that could help with this.
Is the machine plugged directly to a wall socket? if not try doing this, any extensions could cause a volt drop when the spindle starts.
Is the computer located close to the machine and using the standard USB cable?
The USB cable should not be longer than 2M and must not be wrapped around the mains lead or other cables.
Internal to the machine you can see the USB cable connected to the bottom left of the controller card. Could you unplug this and try connecting directly from the Computer to the controller and see if this improves things.
The USB cable inside the cabinet is running inside the trunking, if you remove the lid you could remove the cable and run it along the bottom of the cabinet as far away from the yellow spindle drive as possible. This may help.
Hi.
I took your advice and removed the USB connectors located on the side of the machine out of the equation, the USB cables now go directly from the PC into the internal USB connectors inside the machine.
Since I have done this the machine has worked without problems.
The only drawback is that I now have two holes in the side of the machine where the USB cables run through; I'll laser cut some acrylic disks with a hole in the middle for the cable to blank them off.
I'm not by the machine at the moment so have included a stock photo of the USB bulk head connectors that I have removed just in case you don't understand what I have done.
Thanks for your help.
Rich.
USB to USB Bulk Head Conector.jpg (19.01 KiB) Viewed 28632 times
Thanks for the update.
I remember the earlier USB bulkhead adaptors breaking in the middle...
The more connectors and adaptors you go through, the less reliable it's going to be. So I think you're best sticking with your current fix and blanking the holes off.
