M/C limit Error
Trying to cut a simple file on 6600 router. It cuts for about 3 seconds and then I get this error message:
M/C Limit Error: Machine Error Linear Move Exceeds Limits.
Anybody any idea what is going wrong?
Sarah
Re: M/C limit Error
In VR Milling 5 you can use the blue info button to see where the program is going outside the movement limits of the machine
viewtopic.php?f=37&t=3646
You might have the Z work offset set too low or the X and Y set too close to the edge of the table
Re: M/C limit Error
This problem indicates the program is telling the machine to move outside the working envelope of the machine. The error message will tell you which axis it is.
You will have to either reposition your workpiece and datum or adjust the head if it is the Z axis.
