Config files and Toolsets location
I'm a newbie on the forum, i need to copy the offsets configuration off a laptop and on to other pc's so when VR Milling is loaded the files are already in place
Where do i find these files
Re: Config files and Toolsets location
Is it VR Milling v2.xx or v5.xx ?
These posts may help anyway:
viewtopic.php?f=2&t=166
viewtopic.php?f=1&t=2970
In VRMilling2 they are probably stored in the files windmill.mol and windmill.mtd - you can open them in notepad to see if the numbers match the software.
Its V5 and yes i think one of them post will help
many thanks
There is a far simpler solution.
In the software that has the offsets with the offset window open and active go to the Offset/Tooling menu at the top of the screen.
Select advanced.
Go to the menu again and you can save the alloffsets.MOF file to any location (say a memory stick).
Then open the new PC, open the offset window and then the Offset/Tooling menu again. Now again select advanced the select Load all and browse for the offset file on the memory stick and all should then work!
:D
